How to: field rows
November 15, 2012 12:13pm
  • #1 / Nov 15, 2012 12:13pm
    paolome
    Building a safecracker form, I need to have a field with many rows to write in.
    How can I do to avoid a single-line field?
    <label for=“breve”>Descrizione breve</label>
      <input type=“extendedtext” name=“breve” id=“title” value=”{breve}” size=“50” rows=“10” maxlength=“100”><br>
    thank you
  • #2 / Nov 16, 2012 1:56pm
    Rob Allen
    Try replacing
    with something like
    <textarea name=“breve” id=“title” cols=“50” rows=“10”>{breve}</textarea>
  • #3 / Nov 17, 2012 3:29am
    paolome
    If I try, I get a text field with only two small short rows. Changing the value of the rows and cols, the result does not change.
  • #4 / Nov 17, 2012 7:02am
    Rob Allen
    Make sure you haven’t got any CSS that restricts the size of textarea elements.
  • #5 / Nov 18, 2012 2:52am
    paolome
    Ok. Thank you!
  • #6 / Nov 18, 2012 3:45pm
    paolome
    Fixed dimensions in testarea, but now another issue:
    {exp:safecracker channel='blog' return='reserved/segnalazioni' include_jquery='no'}
    Azienda inadempiente  <input type="text" id="title" name="title" value="{title}" maxlength="75" size="75"rows="10" cols="30"></p>
      Luogo, circostanza, data della segnalazione {field:testo}
      Descrizione dettagliata dell'inadempienza da segnalare:{field:descrizione}
     <input type="submit" value="Submit" />
    when I try to write, I get:
    “The URI you submitted has disallowed characters.”
    Any sugggest?
  • #7 / Nov 19, 2012 12:58pm
    Dan Decker
    Hi paolome,
    Are you wanting to create a new entry with SafeCracker or edit an existing entry? SafeCracker expects either a url_title parameter or entry_id parameter, so try this for me:
    {exp:safecracker channel='blog' return='reserved/segnalazioni' include_jquery='no' url_title=""}
    Can you show me a sample of the content you have in one of the fields? It may be some special accent characters as well.
  • #8 / Nov 19, 2012 1:11pm
    paolome
    After a little attempts I solved by myself. The problem was outside the syntax of safecracker. Thank you for your kind help, Dan!
  • #9 / Nov 21, 2012 3:20pm
    Dan Decker
    Hi paolome,
    Oh, good to know you found the culprit! I’m happy to offer assistance!
    If you need anything else, please let me know!
