Site migrated and templates not found on server.
October 12, 2012 12:56am
  • #1 / Oct 12, 2012 12:56am
    i just migrated a site to another server. The home page loads just fine and the CP loads just fine but when i click on a link i get this error:
    Not Found
    The requested URL /deyasglutenfree/about was not found on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    it works perfectly on the old server. I went through and reset all these to the correct path:
    Admin ‣ General Configuration
    Admin ‣ Security and Privacy ‣ Captcha Preferences
    Admin ‣ System Administration ‣ Emoticon Preferences
    Content ‣ Files ‣ File Upload Preferences
    Members ‣ Preferences
    Design ‣ Templates ‣ Global Preferences
    Admin ‣ Channel Administration ‣ Channels
    I also tried getting ride of the .htaccess file and that had no effect. If i type manualy into the url /deyasglutenfree/index.php/about than it works. Can not figure out what is causing this? As i said i erased the .htaccess file all together and it had no effect.
  • #2 / Oct 12, 2012 1:01pm
    Oh also here is the url to the site’s home page ->  http://clients.tierratechnology.com/deyasglutenfree/
  • #3 / Oct 12, 2012 2:02pm
    hello i am currently trying to upload the site again to make sure i have an exact copy so it can not be seen with the correct issue. I wil let you know when it is back and ready for viewing, thank you
  • #4 / Oct 12, 2012 2:48pm
    alright i re-uploaded the site again to make sure there were no mistakes and i am getting the same error when clicking on any links on my site. Any help would be great!!!!
    Thank you
  • #5 / Oct 12, 2012 3:12pm
    I have just found that if i get ride of the htaccess file than the error changes a little. With the htaccess file in place i get this error:
        Not Found
    And when i get ride of the htaccess file i only get this:
        Not Found
  • #6 / Oct 14, 2012 12:54pm
    Kevin Smith
    Hi Tierra Interactive,
    So when you remove the .htaccess and type in /deyasglutenfree/index.php/about, that works? It sounds to me like your new server just has some different settings in terms of its .htaccess rules and what it will and will not allow. Has the URL changed when you changed servers or is it still the same? If it’s the same and the .htaccess worked on the former server but not this one, I’d recommend checking with your host or your sysadmin to see what might be blocking the .htaccess on the new server.
  • #7 / Oct 15, 2012 11:37am
    Your almost there but not quite. With or without the htaccess file, if i type in the full url with index.php in it than it finds the page. But if i click on a link the page is not found. Again that is with or without the htaccess file. The only behavior that changes with the htaccess file is the error message. Do you still think it has to do with the server settings?
    I just spoke with a tech from my server and he said that the folders are just not being found. So it must be a setting in the CP that im missing but i went through all the Expression engine checklist?
  • #8 / Oct 15, 2012 11:43am
    also we have several other EE sites setup on this server that work well with the htaccess file. So im guessing it is not the server settings.
  • #9 / Oct 15, 2012 12:24pm
    Also, a lot of the css is broken within the site
  • #10 / Oct 15, 2012 1:47pm
    Hello PROBLEM SOLVED. IT was the htaccess file, just not sure exactly what. I replaced the htaccess file with a much simpler htaccess file and it works!
  • #11 / Oct 16, 2012 11:10am
    htaccess can just be a bear sometimes.  Love it though I do when it works!  Glad you got it squared away, and thanks for letting us know the solution.  Anything else crops up, post back and we’ll take a look!
