Exclude latest month entries
September 27, 2012 5:17pm
  • #1 / Sep 27, 2012 5:17pm
    EmilyLimeRed
    So you know how you can set it to only display entries from the latest month using
    {exp:channel:entries channel="journal" dynamic="off" display_by="month" limit="1"}
    is it possible to then exclude that month’s entries from another regular channel entries call?
    I have it set up so that the current (latest) month’s entries appear in a box at the top, and then I want it to be that all the rest appear below in a separate box, but currently it’s showing the latest month’s entries in both locations. Is it possible to exclude the latest month’s entries from the second box?
  • #2 / Sep 28, 2012 3:00pm
    Dan Decker
    Hi EmilyLimeRed,
    You would need a way to exclude the entry IDs from your second tag pair.
    Using something like Stash would let you store the entry_id in a variable and then use the “not” modifier on the second entries tag pair.
      {exp:stash:set name="exclude"}{entry_id}{/exp:stash:set}
    Then
    {exp:channel:entries channel="journal" entry_id="not {exp:stash:get name="entry_id"}"}
    Let me know what you think!
