URGENT: Problem after restoring backup when upgrade failed
September 26, 2012 9:55am
  • #1 / Sep 26, 2012 9:55am
    marijn1412
    After failing to upgrade from 2.1.1 to 2.5.3 I tried to restore my backup. But after putting all the backup files back on the server, changing the necessary permissions, cleared my database and imported the backup db, I was unable to see my website or get in to the control panel (white screens)
    I turned on debugging and got the following message:
    A PHP Error was encountered
    Severity: Notice
    Message: Use of undefined constant AJAX_REQUEST - assumed ‘AJAX_REQUEST’
    Filename: core/EE_Exceptions.php
    Line Number: 62
    Severity: Notice
    Message: Trying to get property of non-object
    Line Number: 64
    I tried uploading the backup files via another ftp client, but that didn’t help. I’m stuck and the website needs to be up and running as soon as possible!
  • #2 / Sep 26, 2012 11:16am
    marijn1412
    I inserted
    echo($message);
    onto line 60 of /system/expressionengine/core/EE_Exceptions.php
    and that gave the following message:
    Unable to load your default controller. Please make sure the controller specified in your Routes.php file is valid.
    I checked my routes.php file and there it says:
    $route['default_controller'] = "ee/index";
    Which seems to me is fine.. stuck again. Anyone?
  • #3 / Sep 26, 2012 12:38pm
    marijn1412
    Problem solved… it seems while backing up, the name of the controllers folder was changed.
    Still I’m unable to upgrade to 2.5.3 from 2.1.1, but at least the site is live again.
  • #4 / Sep 27, 2012 3:09pm
    Kevin Smith
    I’m glad to see you were able to get back to good shape after restoring! Can we help you with that update now?
    What problems were you having getting updated from 2.1.1 to 2.5.3?
  • #5 / Sep 27, 2012 5:37pm
    marijn1412
    Kevin, I replied on the other thread http://ellislab.com/forums/viewthread/224664/
    This thread can be closed
