Login redirects to itself with no errors reported
September 25, 2012 9:53am
  • #1 / Sep 25, 2012 9:53am
    Russ Back
    Hey guys
    I’ve been grappling with this on different servers and sites for as long as I can remember with EE2. It’s intermittent but basically when submitting a valid login, the login form displays again with no errors displayed. This tends to happen when a server is restarted for any reason, that’s the only thing I can find that is common.
    I’ve tried setting require_ip_for_login to ‘n’, setting session types to ‘c’ and ‘s’, clearing browser and EE cache, clearing out the session and logged in users tables, but nothing gives. even when i dump the table out to a different server I get the same.
    When I look into the code I can see that the authenticate() method of the login controller runs through to the end and redirects to the CP homepage, however it never gets there - when trying to echo something from the start of the index() of the homepage controller, nothing happens, so it must be redirecting somewhere else. Where can I look to debug this further? I can’t see how the redirect from login to homepage controllers could be intercepted by anything else.
    This happens on all versions of EE 2 that I’ve worked on. Sounds drastic but that’s what I’ve found.
  • #2 / Sep 25, 2012 10:02am
    Russ Back
    I should add that this only ever affects the cp login - front end login never has any issues.
  • #3 / Sep 25, 2012 5:30pm
    Dan Decker
    Hi Russ,
    We see this often enough, and it is frustrating.
    Symptoms vary from install to install but it seems related to cookies. Clearing your ExpressionEngine related cookies should prevent the refresh.
    What do you have for Cookie Settings in the Control Panel?
  • #4 / Sep 25, 2012 6:27pm
    Russ Back
    Hey Dan
    There must be a way to debug this surely, or at least report the issue to the user? Users are left without the ability to login and administer sites.
    I completely reset Chrome back including ALL cookies and still no joy, so there must be something else going on?
    Cookie settings are all blank (domain, path and prefix)
  • #5 / Sep 26, 2012 6:17pm
    Kevin Smith
    Hey Russ,
    Let’s see what we can find looking at this first-hand. Be on the lookout for an email from me!
  • #6 / Sep 27, 2012 2:30pm
    Kevin Smith
    Hey Russ, just checking to make sure you got my email. Do you need me to send it again?
