Similar problem with ft.md_notes. Site is down now after upgrading to EE2.
September 03, 2012 5:12pm
  • #1 / Sep 03, 2012 5:12pm
    qruxart
    Hi Lisa,
    I just updated another website to EE2 that now also has the same error referenced in the above link:
    Error
    Unable to load requested field type file:  ft.md_notes.php.
    Confirm the fieldtype file is located in the expressionengine/third_party/ directory
    You mentioned that I needed to remove the exp_extension line. Where would I find that in order to remove it?
    The site is currently offline because of this issue and I would like to get it back online as soon as possible.
    Thank you
    Andrew
  • #2 / Sep 04, 2012 11:27am
    Hi, qrux -
    That line would be in the database in exp_extensions, but you might first want to check for an update or contact the author to see if there is one.
    I hope that helps!
  • #3 / Sep 05, 2012 12:39am
    qruxart
    I was able to contact the developer of the plugin and he suggested going into the database and looking at exp_channel_fields in the field_type column and deleting all instances of md_notes and replacing it with just simply “textarea”. I was able to do just that and it worked. I guess EE was looking for the md_notes field type, which doesn’t exist, so it crashed. A very helpful reply. So far the site is good to go. Thanks!
  • #4 / Sep 06, 2012 11:11am
    Thanks for updating us, qruxart! I"m glad that you are back on track and running.
    I anything else comes up, please do let us know!
