Blank segments - am I missing something?
July 04, 2012 6:34am
Subscribe [4]
  • #1 / Jul 04, 2012 6:34am
    Steve Abraham
    Let’s make a couple of assumptions first:
    - Strict URL setting is enabled.
    - “Segment X” is blank/non-existant.
    {exp:channel:entries channel="[CHANNEL]" dynamic="no" url_title="{segment_x}" require_entry="yes" limit="1"}
     {if no_results}
      {redirect="404"}
     {url_title}
    To my mind this should throw a 404, or at the very least just show a blank template. What in fact happens though, is it spits out the url_title of the last entry in [CHANNEL].
    Now; is this expected behaviour (if so it doesn’t seem right), or do I have something weird going on. Checked on a few installs and it seems to behave the same way in all of them.
    Having used EE for years on countless installs I can’t quite get my head round why I’m only noticing this now.
  • #2 / Jul 04, 2012 6:42am
    johnwbaxter
    What happens if you take out limit=1 ?
  • #3 / Jul 04, 2012 6:44am
    Max Lazar
    I just check it on my install (ee 2.5.2), works just fine:
    Status: 404 Page Not Found
  • #4 / Jul 04, 2012 6:47am
    Max Lazar
    just for sure - what do you have for “404 Page” setting?
  • #5 / Jul 04, 2012 6:54am
    Steve Abraham
    I get *every* url_title from that channel…
  • #6 / Jul 04, 2012 6:55am
    Steve Abraham
    Bizarre it’s working for you - utterly bizarre…
    My 404 is set to a working 404 page.
  • #7 / Jul 04, 2012 6:56am
    Steve Abraham
    I should also add, removing require_entry makes no difference to anything.
  • #8 / Jul 04, 2012 6:57am
    johnwbaxter
    Good, just checking….
  • #9 / Jul 04, 2012 7:08am
    Steve Abraham
    We’ve now tested this and getting the same behaviour on 3 different hosting environments; bog standard Apache, FastCGI PHP+Apache and Apache+custom worker module, no difference.
    Also removed .htaccess, also no difference.
    Tested on two currently live EE sites and one brand new fresh install, no difference.
  • #10 / Jul 04, 2012 7:10am
    Max Lazar
    I just tested it on v2.4.0 (20120123):
    - if blank - no 404, just last entry
    - if some wrong url_title - 404
  • #11 / Jul 04, 2012 7:11am
    Steve Abraham
    Yep, that’s the results I’m seeing - but I’m getting them on 2.5.0 and 2.5.2…
  • #12 / Jul 04, 2012 7:24am
    Max Lazar
    as solution -  put the space before {segment_x} 😊
    url_title=" {segment_x}"
    So why it is happend:
    1. require_entry works only if you have dynamic=“yes” - so in your example is just ignored
    2. for blank segment channel is ignore url_title as parameter
    I can say that for blank segment case you have next template
    {exp:channel:entries channel="[CHANNEL]" dynamic="no" limit="1"}
     {if no_results}
      {redirect="404"}
     {url_title}
  • #13 / Jul 04, 2012 7:34am
    Steve Abraham
    That’s interesting, Max - though the space before the segment feels a little “hacky”...! :D
    I think the answer for now is that I just wrap the whole channel:entries tag in a conditional that checks the segment is not blank.
  • #14 / Jul 04, 2012 7:44am
    Max Lazar
    agree - this is right way
  • #15 / Jul 05, 2012 11:00am
    Shane Eckert
    Hey Steve,
    Where are you at now? There have been a lot of responses, are you back in business?
    Please let me know.
