Hello,
Can I have relationship channel field but show only from the author in Control Panel? Is there’s a setting that I missed.
regards,
June 28, 2012 12:56pm
Subscribe [2]#1 / Jun 28, 2012 12:56pm
Hello,
regards,
#2 / Jun 29, 2012 1:19pm
Hey Tyas,
Thank you for posting your question here on the ExpressionEngine forums.
If I understand your question correctly, you would like the relationship field to list only posts that belong to that author? Is this correct?
This is not possible, but I like the idea. Would you be willing to file a Feature Request?
#3 / Jun 29, 2012 7:02pm
Yes sir, that’s right.
Yes its good to know only the author relationship field show. Others entry will not show, it will usefull when so many user can access control panel and many entries.
I will write it in the future request then. Regards.
#4 / Jul 02, 2012 12:04pm
Hey Tyas,
Thank you for filing the request.
