https://support.ellislab.com/bugs/detail/16142/
I have the same error mentioned here and I have version 2.5, recently updated. to test, I tried with two files that come and bug correction does not work.
June 01, 2012 9:00pm
Subscribe [1]#1 / Jun 01, 2012 9:00pm
#2 / Jun 01, 2012 9:17pm
HELLO, i read next support article:
http://ellislab.com/expressionengine/user-guide/modules/metaweblog_api/index.html
Connecting with a Metaweblog API Compatible Program
MarsEdit
Ecto
are compatible only this program?
thanks.
#3 / Jun 01, 2012 10:23pm
the first thing I did was put the url of the page, not the blog the latter is not being logged in the control panel while you are creating the post, not sure if this will affect anything, but if we have enabled that can logear several at a time may include,
then I entered the username and password (although I have to say that I have generated a new password before doing this).
Also, I have to say that I have chosen another type of blog, other than wordpress and sharepoint
I finally chose the MetaWeblog API to publish, everything else has not been a problem,
add exist one app for ee (iExpression - 7 € aprox.) for publish for iphone of red when excited, very good , all chanels edit and post.
un saludo.
#4 / Jun 02, 2012 2:03am
There is a better option as it gives the first post and I also fill in the data as in the previous post, and then instead of choosing, MetaWeblog API, choose from movable type, Why choose movable type? as well that you have the MetaWeblog API allows us on the far right of the top bar, giving to see everything:
established categories,
keywords (but does not put in place, I’ve tried)
the date of publication,
comments, open, closed
pings,
appointment,
url of links and reference
