Content > Pages menu visible even when Pages Module not active
March 24, 2012 10:30am
  • #1 / Mar 24, 2012 10:30am
    Michael Rog
    On some of my sites, the Content > Pages submenu is visible, even though the Pages module has never been installed. This seems to happen on sites that use EE 2.3 and Structure.
    I wouldn’t mind it, except that it creates conflicts with Structure and throws SQL errors if I try to edit content after navigating to the Publish/Edit screen via the Pages sub-menu.
    The issue seems to be resolved in newer installs, using EE 2.4 and Structure 3.2.2. In older installations, the problem can be resolved by uninstalling Structure, installing/uninstalling Pages, and re-installing Structure. (i.e. Running the Pages uninstaller clears the Pages menu from the Content area.)
    However, for existing sites that have this issue, where I cannot reasonably nuke all of my Structure pages, it’d be helpful to know where in its core EE decides whether or not to show that menu, so I can try to get rid of it by some manual process.
  • #2 / Mar 26, 2012 12:42pm
    Shane Eckert
    Hello Michael,
    We really do not like to see users modify core files. Is this the only option you have? Are you able to update the other sites to the latest version as that seems to be a consistent fix?
    Please let me know your thought.
  • #3 / Mar 26, 2012 1:17pm
    Michael Rog
    Unfortunately, while newer installs don’t manifest the same glitch, upgrading from an old version doesn’t seem to eliminate the issue.
    I need to figure out specifically what activates the Pages menu so I can turn if off.
  • #4 / Mar 26, 2012 1:36pm
    Michael Rog
    Bah. Actually, this turns out to be not an issue with EE at all. It’s being caused by the MX Extended Content Menu Accessory. Which is deprecated for EE 2.4 anyway. Sorry for the confusion.
  • #5 / Mar 26, 2012 1:51pm
    Andrew Fairlie
    Makes sense! If you ever want more control over the admin menu bar in future, you could try Zoo Flexible Admin. That’s about as granular as you can be!
  • #6 / Mar 27, 2012 7:47pm
    Sean C. Smith
    Micheal,
    Good to see you found the cause of your problem. I would also like to second Andrew’s suggestion for using Zoo Flexible Admin - it’s really top notch.
    Sean
