In the past i used “Search Results” by planet-ee.com. Which basically just enhances the displaying of the internal EE search-results. I’m very tempted to tryout Low-Search on an upcoming project , as it uses “MySQL’s native full-text functions” to find possible relevant entries as well.
I’ve added / modified the core-search module to support searching for future entries in certain channels. Here are the modifications i made to the search-module, if you don’t mind me sharing them.
Allow show_future_entries for certain channels:
show_future_entries=“no”
future_entry_channels=“2|3”
// /system/modules/search/mod.search.php
// around line 336, add a new parameter
'future_entry_channels' => $this->EE->TMPL->fetch_param('future_entry_channels',''),
// around line 643, under /** We only select entries that have not expired
// change the entire block to use the new parameter
if ( ! isset($this->_meta['show_future_entries']) OR $this->_meta['show_future_entries'] != 'yes')
// future entries for some channels, like event-channels
$future_entry_channels = $this->_meta['future_entry_channels'];
if(empty($future_entry_channels))
// regular show_future_entries="no"
$sql .= "\nAND exp_channel_titles.entry_date < ".$this->EE->localize->now." ";
else
// allow some channels to have future entries
$future_entry_channels = explode('|', $future_entry_channels);
$sql .= "\nAND (exp_channel_titles.entry_date < ".$this->EE->localize->now." OR exp_channel_titles.channel_id IN(".implode(',', $future_entry_channels).") ) ";
if ( ! isset($this->_meta['show_expired']) OR $this->_meta['show_expired'] != 'yes')
$sql .= "\nAND (exp_channel_titles.expiration_date = 0 OR exp_channel_titles.expiration_date > ".$this->EE->localize->now.") ";
