Site never loads, "Waiting for..."
November 30, 2011 9:14pm
  • #1 / Nov 30, 2011 9:14pm
    adro
    I’m having a weird issue that I’ve never seen before…I have an install that was moved around a few times and I can confirm it was working perfectly at one point.
    I originally had the install on a dummy domain and I’ve since tried moving it to a subdomain on my site. I’ve done the migration like I always do (Deeploy Helper, permissions, etc) but this time the site just loads forever and never actually appears. My paths are all correct (I’ve triple checked) and it doesn’t seem to load…Sometimes, if I wait like 10 minutes, the site will like *kinda* load, but there’s something totally messed up. It’s currently located at http://boomphones.adamrotman.com and as a test, I tried putting it on a new subdomain http://boom.adamrotman.com with the same results.
    Btw, I can access the CP without a problem…This only seems to be happening on the frontend.
    Version is 2.1.3 Build: 20101220
  • #2 / Nov 30, 2011 10:01pm
    Brad K Morse
    Do you see any errors in the error log? If you do, can you copy and paste those errors here?
  • #3 / Dec 01, 2011 12:43am
    adro
    Nothing in the server error log…
  • #4 / Dec 01, 2011 8:44am
    Brad K Morse
    Create a new template, just put a word in there, try to display that, see if it appears. If nothing appears, then it isn’t an EE tag problem.
  • #5 / Dec 01, 2011 9:05am
    adro
    Ok so removing everything from the template except one word does seem to work…
    I what’s throwing it off…Time to start removing lines…
  • #6 / Dec 01, 2011 9:11am
    Brad K Morse
    Good luck!
  • #7 / Dec 01, 2011 11:10pm
    adro
    Thanks for your help!
  • #8 / Dec 02, 2011 11:40am
    Kyle Cotter
    Hey adro,
    Sorry to see this happening to you.
    As Brad suggested, taking the template apart piece by piece here is the best solution.
    Perhaps there is a word in there that is triggering some security precaution like mod_security.
    Keep us posted with what you find!
  • #9 / Dec 02, 2011 11:44am
    adro
    Hey Kyle - totally just figured out it like 10 minutes ago…finally.
    It was the TweetLine plugin (v2.1) !!!
    Glad to have found out what was causing all that trouble!
  • #10 / Dec 02, 2011 12:00pm
    Kyle Cotter
    Hey Adam,
    Glad to see you got everything working!
    If you have any more questions, feel free to start a new thread.
    Thanks! 😊
