How can i create XML sitemap
October 06, 2011 9:13pm
Subscribe [6]
  • #1 / Oct 06, 2011 9:13pm
    farrukhny
    HI
    I am try to generate XML sitemap but dont know how, my website structure is
    http://www.domain.com/template/template/entry
    i have more then 500 entry pages and everyday it is increasing to 5-10 pages please help. some example.
    my EE 2.2.2
  • #2 / Oct 06, 2011 11:31pm
    mz91184
    I found a link to some docs on how to create one with EE (http://expressionengine.com/wiki/Google_Sitemaps).  I now usually use Structure for navigation which has xml sitemaps built into template tags.
  • #3 / Oct 07, 2011 7:37am
    Thanks for the assist, mz91184.
    That particular article is for EE1.x, so you’d need to modify it to work with EE2.x.
    Or you can look at:
    http://devot-ee.com/search/tags/tag/sitemap
    Does that help?
  • #4 / Oct 07, 2011 9:13am
    farrukhny
    Thanks for help but does has any different way to create xml sitemap?
  • #5 / Oct 07, 2011 11:18am
    Matt:P
    Hi Farruk
    I use this: http://www.xml-sitemaps.com
    They also have a standalone version which you can use on your own server.
    Looking forward to other suggestions 😊
  • #6 / Oct 07, 2011 12:11pm
    amityweb
    I just create a template with the code below, and set it to XML, then insert the channel entry tag to generate the links.
    <?xml version="1.0" encoding="UTF-8"?>
    <urlset xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sitemaps.org/schemas/sitemap/0.9 <a href="http://www.sitemaps.org/schemas/sitemap/0.9/sitemap.xsd&gt">http://www.sitemaps.org/schemas/sitemap/0.9/sitemap.xsd"&gt</a>;
    {!-- Home --}
    <url>
    <loc>{site_url}</loc>
    <lastmod>{exp:stats}{last_entry_date format="{DATE_W3C}"}{/exp:stats}</lastmod>
    <changefreq>always</changefreq>
    1.0</priority>
    </url>
    {!-- Content Pages --}
    {exp:channel:entries channel="content" disable="categories|custom_fields|member_data|pagination|trackbacks" rdf="off" dynamic="off" status="Open"}
    <url>
    <loc>{site_url}site/{url_title}</loc>
    <lastmod>{gmt_edit_date format="{DATE_W3C}"}</lastmod>
    <changefreq>weekly</changefreq>
    0.5</priority>
    </url>
    {!-- Blog List --}
    <url>
    <loc>{site_url}site/blog</loc>
    0.5</priority>
    </url>
    {!-- Blog Entries --}
    {exp:channel:entries channel="blog" disable="categories|custom_fields|member_data|pagination|trackbacks" rdf="off" dynamic="off" status="Open"}
    <url>
    <loc>{site_url}site/blog/{url_title}</loc>
    0.5</priority>
    </url>
    </urlset>
    The template is in my “site” template group, and is called sitemap.xml, so the URL to it is:
    http://www.mydomain.co.uk/site/sitemap
  • #7 / Oct 09, 2011 12:23am
    Dan Decker
    farrukhny,
    Do either of the 2 new suggestions get you closer to your goal?
  • #8 / Oct 09, 2011 12:32am
    farrukhny
    yes thank you guys for help
  • #9 / Oct 09, 2011 12:36am
    Dan Decker
    farrukhny,
    Excellent! If you need any thing in the future, let us know via a new thread.
    Cheers!
