A PHP Error was encountered
Severity: Notice
Message: Undefined property: Rel_ft::$db
Filename: fieldtypes/ft.rel.php
Line Number: 202
Fatal error: Call to a member function select() on a non-object in /system/expressionengine/fieldtypes/ft.rel.php on line 202
I had created a Custom Field Type to test out the Relationship field type
Didn’t need it, tried to delete it
and after clicking delete at this page:
D=cp&C=admin_content&M=field_delete_confirm&field_id=33&group_id=2
Delete Field
Are you sure you want to permanently delete this custom field?
My Custom Field
[Delete]
I received the above error message.
I backed out of the rror page, went back into the Custom Channel Fields for that Channel, the unwanted Custom Channel Field was still there, so I tried to delete it again,
and received the same error message.
I think I am running EE 2.1.3 don’t know what build number, but I can supply this info if somebody tells me how to retrieve it, if it’s needed.
