Location ID search
April 29, 2011 1:44pm
  • #1 / Apr 29, 2011 1:44pm
    dgraydesign
    I’m trying to figure out the best way to handle this need on my client’s site: I have a Channel for Exhibitors in which there’s a filed called “Booth Location.” This field is an ID number. I want to set up an input where a visitor can enter a booth ID# and it takes them to that Exhibitor’s page. I don’t want a search results page - I want it to go directly to the exhibitor’s info page (generated from the ‘Exhibitors’ channel) Any suggestions on how to set this up in EE?
  • #2 / Apr 29, 2011 7:27pm
    the3mus1can
    Try something along these lines (you will probably have to change a lot of the names, but it is a starting place):
    field_name_for_booth_id is whatever you have named the field in the channel that holds the booth’s ID #.
    Search form:
    <form action="{path="exhibitor"}" method="post">
            <label for="booth_id">Booth ID#</label>
            <input type="text" name="search:field_name_for_booth_id" value="" id="booth_id" />
        <input type="submit" value="Lookup" /></p>
    </form>
    Template (exhibitor/index)
    {exp:channel:entries
        disable="categories|category_fields|member_data|pagination|trackbacks"
         dynamic_parameters="search:field_name_for_booth_id"
        limit="1"
        require_entry="yes"
    {if no_results}{redirect="404"}{/if}
    ... other template code ....
    This uses dynamic parameters and here are the docs for them: http://ellislab.com/expressionengine/user-guide/modules/channel/dynamic_parameters.html
  • #3 / Apr 29, 2011 7:39pm
    dgraydesign
    Yes! I had forgotten about being able to limit the search to one custom field. I think this should work well. Thanks!
