There is 1 comment in the comment table and it looks legit so not sure what is going on here? What makes a comment “valid” or invalid? Would like to get this resolved for client asap.
Mike
March 04, 2011 1:15am
Subscribe [3]#1 / Mar 04, 2011 1:15am
Mike
#2 / Mar 04, 2011 1:21am
Purple or 38 !
PS. You might want to try offering up some more detail like, Ohh, I don’t know… some very succinct code from ur template, EE version # and any other general items, all these will greatly enhance the quality of reply 😛
#3 / Mar 04, 2011 1:50am
ok, then. Version of EE is in the title. I tested comments prior to launch and they work fine but when I turned moderation on, I am having this problem.
When you click on the comment with the (1) next to it, you end up on a screen with the “No Valid Comments” message. Not much more I can say from there.
#4 / Mar 04, 2011 1:51am
This is the image of the comments
#5 / Mar 04, 2011 2:03am
Does anything show on the front end ?
Just tried it on my install, found an entry, clicked it and vanished “no valid…” - Then noticed the search field was populated with the article, removed it and bingo!, weird I know.
#6 / Mar 04, 2011 11:38am
wow, I didn’t even notice that but you’re correct Cheif. Fixed my problem as well. This is most definitely a bug.
Mike
#7 / Mar 04, 2011 5:28pm
Since you have the steps down on how to reproduce the error, would you mind reporting to our bug tracker? The link is in my signature.
#8 / Mar 04, 2011 7:11pm
Already took care of it! 😊
#9 / Mar 05, 2011 5:18pm
Hi cityzen,
Thanks very much. For reference, the report is here.
Cheers
Greg
@Cheif, thanks for your help.
