cp theme path issue since move
February 17, 2011 3:58pm
  • #1 / Feb 17, 2011 3:58pm
    i just moved a site from one directory to another (root) and am experiencing css path issues regarding the drop down tabs in the cp navigation. in inspecting the css, it seems the path for these images in css is referencing the old location. aside from the admin/general configuration settings, is there any place else this needs to be changed that i might have missed?
  • #2 / Feb 17, 2011 5:48pm
    Did you check the config.php file?
  • #3 / Feb 17, 2011 5:56pm
    yes, i even added the following to the config file to try to hopefully override any wayward setting:
    $config['configtheme_folder_path'] = "/themes/";
  • #4 / Feb 18, 2011 4:02am
    running with scissors,
    Your config variable is incorret. Use these two and update the path to reflect your own full server path
    $config['theme_folder_path'] = "/home/mysite/public_html/themes/";
    $config['theme_folder_url'] = "/themes/";
  • #5 / Feb 18, 2011 10:45am
    yeah, that’s not working. it’s still pointing to the old path.
  • #6 / Feb 18, 2011 3:22pm
    What version and build are you using? Is this using the MSM?
  • #7 / Feb 18, 2011 4:32pm
    build: 20101020
    no msm
  • #8 / Feb 19, 2011 4:52pm
    Greg Salt
    Hi running with scissors,
    Have you tried clearing all caches at CP Home > Tools > Data > Clear Cached Data?
    Cheers
    Greg
  • #9 / Feb 20, 2011 12:29pm
    yeah, i had done that a couple times already and it seemed to have no effect, however after not touching this site since yesterday, and not doing anything mind you to address the situation, the damn thing now works. go figure. consider this issue resolved. thanks.
  • #10 / Feb 20, 2011 3:58pm
    Sound like a lingering cache issue. Glad it’s working now. Please don’t hesitate to post again as needed.
