I have a weird date issue. I have entry_date and 2 matrix fields with 2 date fields in each. In the entry_date and the first matrix field, time changes. I type 10:00 AM and it renders as 09:00.
Localization settings you’d say, but in the second matrix time renders as 10:00 AM. If I remove DST all three change to an hour earlier yet with an hour’s difference.
It doesn’t make sense! Why should they render differently when the localization settings are the same for them all?
Version 2.1.1 Build: 20101020
