URGENT! Another upgrade error including field types
November 02, 2010 2:23pm
Subscribe [4]
  • #1 / Nov 02, 2010 2:23pm
    Yvonne Martinsson
    This may be related to several other posts.
    I’ve upgraded an install from the beta version to 2.1.1 Build:  20101020 and the Publish/Edit forms don’t display. They include custom fields, field types such as wygwam, channel images and matrix. The tabs have also been customized. Heard about similar issues some time ago, but thought it had been fixed.
    MX Google Maps caused some errors but has been removed and uninstalled. Yet, I had to do it manually in the db. Don’t know if it still can cause any issues.
  • #2 / Nov 02, 2010 2:34pm
    Yvonne Martinsson
    Tried the TRUNCATE `exp_layout_publish`  suggested here, http://ellislab.com/forums/viewthread/169947/. Didn’t work-
  • #3 / Nov 02, 2010 7:45pm
    Yvonne Martinsson
    Solved! Re-uploaded the cp_themes folder. Turns out the folder only includes the Default theme!!! And the Corporate one was used here. Shouldn’t the coprorate, fruit and mobile theme be included?
  • #4 / Nov 03, 2010 9:54am
    Hi, Yvonne. Excellent catch. Recent builds only have the Agile and Default themes. The remaining themes aren’t in there. If you could add a comment to the update doc page, that would help other users who may run into this issue.
  • #5 / Nov 03, 2010 2:07pm
    Yvonne Martinsson
    Done! And for the record, it was the CP theme that broke the upgrade. I don’t know about the site themes as I don’t use them.
  • #6 / Nov 03, 2010 3:07pm
    Glad to see that worked for you. Please post again as needed.
