I’ve placed the auto check Moblog tag in my template, but my entries don’t show up in my page until I hit the manual Check Moblog link in the module.
{exp:moblog:check silent="true" which="all"}
EE 2.1.1 Build 20101020
October 24, 2010 9:49pm
Subscribe [2]#1 / Oct 24, 2010 9:49pm
#2 / Oct 25, 2010 12:28am
Hi, DeltaJo. The way the moblog works is to have the page be accessed. Make sure you’re placing the moblog check on a busy page. Otherwise, you won’t see it checked.
Does that help?
#3 / Oct 25, 2010 2:05am
Am I missing the point? I check the page myself after I email a blog entry. And then again. And the blog entry doesn’t appear.
When I put the tag alone on a separate page —a separate template — and then check it, it does work.
#4 / Oct 25, 2010 9:18am
If a new template works, double check that you aren’t using caching on the page.
#5 / Oct 25, 2010 1:51pm
Hi Sue — well it’s weird. And kind of embarrassing. But a new day brings different results. I tried one last time this morning, putting the code on a page it previously did not work on, and lo and behold, it worked.
#6 / Oct 25, 2010 2:59pm
Very glad to hear it. Please post again as needed.
