EE 2.0PB control panel error
September 02, 2010 6:15pm
  • #1 / Sep 02, 2010 6:15pm
    Andy Slipher
    Help.  I’m having the same issue. My Control Panel page is coming up blank all of a sudden. I’m running EE 2.0 Beta and am planning to update to 2.1 once I work through this issue.
    Here’s the error that’s displayed once I turned on error reporting as suggested by Greg.
    Parse error: syntax error, unexpected T_STRING in /var/www/vhosts/mydomain.com/httpdocs/system/expressionengine/libraries/Accessories.php on line 107
    I’m not even seeing an Accessories.php file either locally or on my server. Am I simply missing a file?
    Thanks.
    Andy
  • #2 / Sep 02, 2010 6:16pm
    Andy Slipher
    Sorry, I just noticed this is under legacy support. I pulled it up on a search. Should I re-post under EE 2?
  • #3 / Sep 02, 2010 9:48pm
    Brandon Jones
    slipher, I moved this over for you.
    The first thing I’d suggest is a version upgrade to 2.1, which will ensure we have a fresh, intact set of files on the server. Let us know how it goes.
  • #4 / Sep 03, 2010 12:52am
    Andy Slipher
    Brandon,
    Thanks for the move. Issue resolved. I found the corresponding file after all (Accessories.php), re-uploaded it to my server and everything seems to be working again. For anyone else reading this, I suspect the problem centers around some changes to my VPS by the host. Files were ‘touched’ during some routine diagnostics by my host. I had some similar issues under another domain (same VPS, different domain) with some corrupted swf files with no apparent explanation.
    Regardless, I plan to update to 2.1 tomorrow.  Thanks again.
    Andy
  • #5 / Sep 03, 2010 3:50am
    Glad you are up and running again. Feel free to start a new thread if you have any questions regarding your upgrade tomorrow.
