Hey guys, I’m back. Swamped with work. I took some time to further investigate this issue, and as Greg suggested, removed .htaccess. It works fine with .htaccess removed. It even worked fine with just index.php removed from the “Name of your site’s index page” field in the General Configuration, leaving .htaccess intact. Simply by removing that from the General Config settings, I was able to post and administrate comments like I would normally.
I was using the exclude method to remove index.php, as my clients were going to be able to create new pages via the Pages Module, and I didn’t wish to edit the .htaccess every time they did.
Is there perhaps some comments config file that needs to be edited? Perhaps remove “index.php” from a path somewhere?
Thanks so much for the help guys. 😊
