Weird If No Results
June 10, 2010 7:34am
Subscribe [4]
  • #1 / Jun 10, 2010 7:34am
    BC Team
    If no results tag is only working if I put a set of empty tags in front like this:
    {if no_results}{/if}
    {if no_results}
        //Some HTML here
    This is occurring inside a query and also in comments tags.
    (EE 1.6.8 - Build:  20100415)
  • #2 / Jun 10, 2010 11:05am
    I can replicate this behavior in 1.6.9 build 20100430.
    Can you please post this to the EE 1.x BugList with a link to this post, and respond back here with a link to the bug report?
  • #3 / Jun 10, 2010 11:20am
    BC Team
    I just submitted to the BugList as requested:
    https://support.ellislab.com/bugs/detail/12739/
    The details that I entered aren’t showing up in the bug list.
  • #4 / Jun 10, 2010 11:28am
    I fixed that part, you’re use of the curly brace caused the text not to show. Thanks for reporting this.
  • #5 / Jun 10, 2010 11:34am
    BC Team
    I don’t know how you replicated but I now think I have this problem actually:
    http://expressionengine.com/docs/modules/query/index.html#3800
    I think maybe the way I have nested the tags:
    {exp:weblog:entries}
    {ff_matrix}
         {exp:query}
              {if no_results}
                //HTML FOR NO RESULTS
              {/exp:query}
    {/ff_matrix}
    {/exp:weblog:entries}
  • #6 / Jun 10, 2010 11:39am
    BC Team
    This seems to work, so even though I don’t care about finding no entries it means the other tags now work.
    {if no_results}{/if} <-- THIS BIT
    {ff_matrix}
         {exp:query}
              {if no_results}
         {/exp:query}
    {/ff_matrix}
    {ff_matrix}
         {exp:query}
              {if no_results}
         {/exp:query}
    {/ff_matrix}
    {exp:comments}
         {if no_results}
    {/exp:comments}
  • #7 / Jun 10, 2010 5:23pm
    I am glad you found a workaround for now.
  • #8 / Jul 07, 2010 3:51pm
    K- I’m not replicating in a quick test:
    {exp:query sql="SELECT title from exp_weblog_titles where entry_id = '111111111111'"}
    {title}
    {if no_results}
    Nada for you!
    {/exp:query}
    I get the expected ‘Nada for you!’.
    Now expect to have a problem if you’re nesting tags- because the no_results may get confusing with regard as to WHICH tag it has no results for.  In the above- well, I try REALLY HARD not to nest a query inside a weblog tag unless I know for sure I’m only getting one results- because it’s going to loop and do a query for each result.  And that’s w/out tossing matrix into the mix.  Be sure you’re not generating hundreds of queries w/out realizing it.
    And that said- if you want them parsed independently- you’d want to move the query to another template- embed that template- pass the variables as embed variables- and then they’ll be processed independently.  But yes- that no_results is for the weblog tag.
    Also- it’s a bad idea to nest the comment tags inside the weblog tag- you can get variable conflicts and it’s just not to be used that way.
    All that aside- are you folks replicating an issue w/out nesting your tags?
  • #9 / Jul 07, 2010 9:08pm
    BC Team
    It was the nesting. Putting a no_results tag outside the query tag it worked.
    Oops, will take the comments out of the weblog tags.
  • #10 / Jul 08, 2010 12:50am
    BC Team,
    Has Robin answered all your questions or do you have any outstanding?
  • #11 / Jul 08, 2010 12:53am
    BC Team
    Yes all fixed.
  • #12 / Jul 08, 2010 1:06am
    Great stuff! Feel free to start a new thread if you have any more questions.
