It seems I can’t implement comments in my site. I read the Comment Module Tags but it does not say nothing on how the comments will appear if you submit comment from the site!
June 28, 2007 10:03am
Subscribe [2]#1 / Jun 28, 2007 10:03am
#2 / Jun 28, 2007 10:09am
Also if I don’t need to create another weblog with custom fields for the comments, how to know where the submitted comments are? It’s so confusing.
#3 / Jun 28, 2007 1:45pm
The Comment Entries tag is used to display comments. I’d suggest looking at the default templates that come with EE, the ‘comments’ template, to see how it all works together. You do not create a weblog for comments; comments are associated with a particular weblog entry.
#4 / Jun 28, 2007 1:52pm
Thanks Derek, I’ll try to read the docs again, to bad I deleted all the default templates that come with EE.
#5 / Jun 28, 2007 1:57pm
If you create a new weblog, you will be given the option to create templates for it automatically. Checkmark “Use one of the default themes”, select Default, and viola!
