Form Validation does not work
June 24, 2014 9:58am
  • #1 / Jun 24, 2014 9:58am
    Zombie1
    Hello all,
    I’m a newbie to CodeIgniter.  I’m having some trouble with my form validation.  My form allows a user to enter a username and password then checks it against a database.  If the username or password do not match the program displays an error message.  If the username and password do match then they are redirected to a page called my_blog.
    Here’s the code for the controller:
    class Form extends CI_Controller {
     function index()
      $this->load->helper(array('form', 'url'));
      $this->load->library('form_validation');
      $this->form_validation->set_rules('username', 'Username', 'required');
      $this->form_validation->set_rules('password', 'Password', 'required');
      if ($this->form_validation->run() == FALSE)
       $this->load->view('log_in');
      else
       $this->load->view('my_blog');
     function user_not_exists($username) {
      $this->load->model('log_in_db');
         $user_check = $this->user_model->user_not_exists($username);
         if($user_check > 0) {
       redirect('my_blog');
       return TRUE;
         else {
       $this->form_validation->set_message('required', 'Username does not match');
             return FALSE;
     function password_not_exists($password) {
         $check_password = $this->user_model->password_not_exists($password);
         if($check_password > 0) {
       return TRUE;
         else {
       $this->form_validation->set_message('required', 'Password does not match');
             return FALSE;
    Here’s the code for the model which the controller links to called log_in_db:
    class log_in_db extends CI_Model {
         $this->db->where('username', $username);
         $query = $this->db->get('users');
         return $query->num_rows();
         $this->db->where('password', $password);
    And finally here’s the code for the log in form which holds the actual form including both textfields for username and password:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html >
    <head>
    <meta http-equiv="Content-Type" c charset=iso-8859-1" />
    <title>Log in form</title>
    <link rel="stylesheet" href="../../../_css/style-sheet.css" media="screen" />
    </head>
    <body>
    <div id="login-form">
     <div id="log-in-form">
       <?php echo validation_errors(); ?>
       <?php echo form_open('my_form'); ?>
        <table>
         <tr>
          <td class="log-in-td" align="left">
           <label for="username" class="login-text">Username</label>
          </td>
         </tr>
         <tr>
           <input name="username" type="text" size="25" maxlength="25" id="username" class="my-textfields" />                                </td>
         </tr>
         <tr>
           <label for="password" class="login-text">Password</label>
          </td>
         </tr>
         <tr>
           <input name="password" type="password" size="25" maxlength="25" id="password" class="my-textfields" />                    </td>
         </tr>
         <tr>
          <td align="center" class="log-in-td">
            <input type="button" id="My-Log-in-button" value="log-in"  />
          </td>
         </tr>
          </table>
       <?php echo form_close(); ?>
      </div>
     </div>
    </body>
    </html>
    If anyone can give me any help to why the error messages aren’t displayed or the user isn’t redirected when they enter a correct username and password.  Thanks in adavance.
