EE will not save templates as text files - and I've tried pretty much EVERYTHING
April 17, 2014 9:48am
  • #1 / Apr 17, 2014 9:48am
    JackWH
    Hi folks,
    THE PROBLEM:
    When editing a template file via the control panel, saving it with “save template as text file” ticked gives the error: “Unable to save your template as a text file”. The template is updated in the database, but not saved out to a file Although the template is saved to the DB it does not reflect any changes on the actual site.
    SERVER CONFIGURATION:
    Design—> Templates—> Global Preferences:
    - Save Templates as Files: Yes
    - Server path to site’s templates:
    /var/www/vhosts/serverxxx-xxx-xx-xxx.live-servers.net/hbr-new-website/system/expressionengine/templates
    (I have tried this with/without trailing slash)
    Permissions:
    - /system/expressionengine/templates and all subfolders and files set as 777
    PHP settings:
    - Safe mode: off
    - open_basedir: /var/www/vhosts/serverxxx-xxx-xx-xxx.live-servers.net/hbr-new-website/:/tmp/
    - $_SERVER[“DOCUMENT_ROOT”]: /var/www/vhosts/serverxxx-xxx-xx-xxx.live-servers.net/hbr-new-website
    Any ideas? I’m absolutely stumped :-(
  • #2 / Jun 06, 2014 2:26am
    Magnusvb
    I had a similar problem. After I had moved the site to the production server, I could no longer save - locally – templates as text files.
    So, I did a workaround:
    1. Created and saved the template on the production server.
    2. Downloaded that using FTP.
    3. Changed the permission to 666 on the file.
    After that I had no issues to change the template inside admin - and save it as a file.
    Regards, Magnus
