I’m using v2.5.2. I am using PHP to limit the number of characters rendered from a channel entry. Everything works ok until I try use an a-tag in my channel entry “full_entry” field.
Here is the section of the template with the problem:
{exp:channel:entries channel="blog" orderby="date" sort="desc" limit="3" pagination="bottom" }
<section><b><em>{summary}</em></b>
<?php
$position=400;
$message="{full_entry}";
$post = substr($message, 0, $position);
echo $post;
echo "...";
<div class="span8">
<span class="dateTime">Posted by <span class="author">{author}</span>
{categories}
<a href="http://{path=blog}">in {category_name}</a> •
{/categories}</span>
<a href="http://{url_title_path=blog/single}"> Permalink</a>
</div>
<div class="span3">
<a href="http://{url_title_path=%27blog/single%27}" class="readmore pull-right">Read More>></a>
</div>
</section>
{/exp:channel:entries}I do have PHP enabled on the template. Is this some problem with escaping?
Thanks in advance,
Justin
