I’ve just upgraded to php 5 and since this upgrade the control panel is not displaying the css. See - http://www.ardwyn.net/carsystem/index.php
Many thanks
Clive
May 03, 2012 5:28am
Subscribe [3]#1 / May 03, 2012 5:28am
Many thanks
Clive
#2 / May 03, 2012 2:32pm
Hi Clive,
Once we get this sorted out, you should really update your version of ExpressionEngine. The version you are running is 5 years old mate!
How did you upgrade to PHP 5? Did you move servers, or did the host update your existing server?
Are you able to login to the Control Panel, even though it will be un-styled we can still check URLs and paths. Check the settings in
CP Home › Admin › System Preferences › General ConfigurationDo you still have /themes in your web-root?
I look forward to your reply.
#3 / May 08, 2012 12:06pm
Hi Dan,
This is a website which I haven’t looked at for a while and I definitely need to upgrade my version of EE.
The host upgraded the PHP version.
Yes I am able to login to the Control Panel & I still have the themes in my web-root.
Clive
#4 / May 11, 2012 12:36pm
Hey Wales New Media,
Are you able to upgrade soon?
Please let us know.
Cheers!
#5 / Nov 08, 2012 12:56pm
so there is no way to fix this?? Except to upgrade EE?
#6 / Nov 08, 2012 12:59pm
Hey adambeazley,
What issue are you experiencing? The CSS not working?
What version of ExpressionEngine are you on?
Often times this is solved by simply uploading the themes folder again and double checking the perms.
Please let me know what your symptoms are.
