problem with ee2 upgrade
October 21, 2011 4:53am
Subscribe [4]
  • #1 / Oct 21, 2011 4:53am
    Tony Gurnick
    i get this error when going directly to a forum reply
    A PHP Error was encountered
    Severity: Warning
    Message: Division by zero
    Filename: forum/mod.forum_core.php
    Line Number: 1668
    Severity: Warning
    Message: Cannot modify header information - headers already sent by (output started at ....  /system/codeigniter/system/core/Exceptions.php:170)
    Filename: libraries/Functions.php
    Line Number: 393
  • #2 / Oct 21, 2011 12:46pm
    Mark Bowen
    Hi Tony,
    Which version of ExpressionEngine are you running here?
    If not the latest version then could you possibly try upgrading to 2.3.1 and see if this fixes the problem up for you?
    It will at least mean that we’re all on the same page code wise for testing purposes at least and that you will have a totally fresh set of files on your system.
    Also was this a brand new install of ExpressionEngine or an update? If an update then did the update go smoothly or did you receive any errors when performing the update? If you did have errors then can you let us know what they were please.
    Mark
  • #3 / Oct 22, 2011 9:20am
    Tony Gurnick
    wow that was a very poor bug report from me.
    Let me try again.
    I upgraded from EE1 to EE2.  This error happened from day one.
    Yes i did have problems upgrading due to duplicate entries in various tables.  But i sorted that out, and upgraded successfully.
    Im now running 2.3.
    It only seems to be an issue with the viewreply url.  view thread works fine.
    what happens is I get a subscription notification and i click the link in my email and it goes to viewreply
    maybe i have something configured wrong?
  • #4 / Oct 24, 2011 10:46am
    Mark Bowen
    Hi Tony,
    You say that you had problems when upgrading from 1.x to 2.x but you managed to sort those problems out. What were the problems and how did you sort them out if I might ask?
    Mark
  • #5 / Oct 24, 2011 6:00pm
    Tony Gurnick
    i think member data tables were out of sync.  only by 2 or 3 records
  • #6 / Oct 25, 2011 8:48pm
    Dan Decker
    Hi Tony Gurnick,
    Did you make sure to update your Discussion Forum to the latest version as part of your upgrade process? What version of Forum are you running?
  • #7 / Oct 26, 2011 5:21am
    Tony Gurnick
    yes dan decker i did.  ( sorry but your name DEMANDS to be said in full - was not trying to be curt 😊
  • #8 / Oct 26, 2011 10:01pm
    Dan Decker
    Tony Gurnick,
    Ha! You are not the only person to tell me that 😉 Our very own James Mathias insists on doing the same.
    Are you by any chance using .htaccess to remove index.php?
  • #9 / Oct 27, 2011 5:46am
    Tony Gurnick
    You are right DAN DECKER, I am not using an htaccess
  • #10 / Oct 28, 2011 6:04pm
    Kevin Smith
    I hate to double back on this, Tony, but are you sure you’re running the latest Discussion Forum release? I ask because line 1668 in forum/mod.forum_core.php of the latest release doesn’t have any math in it (so there shouldn’t be a “division by zero” error), but that same line in the release before the most recent does. I have a feeling that might be the cause of our problems here.
    Just for the sake of troubleshooting, could you please download the latest Forum release and upload it to your server again?
  • #11 / Oct 29, 2011 8:26am
    Tony Gurnick
    ok so heres the thing.
    at the start of the conversation i thoought this version -> ExpressionEngine Discussion Forum - version 3.1.5 (20110630)
    was the latest.  but its 316 now isnt it?
    so my answer is yes and no.
  • #12 / Oct 31, 2011 12:10am
    Dan Decker
    Tony Gurnick,
    Dan Decker here, you are correct? 3.1.6 is the most current version of Discussion Forum. Can you verify that you have that installed on your system. If you are completely up-to-date, do you still see the error?
