[solved] .htaccess rule to allow routing to subfolder - not to be processed by CI
September 14, 2010 4:46pm
  • #1 / Sep 14, 2010 4:46pm
    Zelf
    This is my current .htaccess.  I have a subfolder that contains another application not run by CI. What do I add to this .htaccess so CI will not treat this folder as part of the CI application framework.
    RewriteEngine on
    RewriteBase /
    #Removes access to CodeIgniter system folder by users.
    #Additionally this will allow you to create a System.php controller,
    #previously this would not have been possible.
    #'system' can be replaced if you have renamed your system folder.
    RewriteCond %{REQUEST_URI} ^system.*
    #Checks to see if the user is attempting to access a valid file,
    #such as an image or css document, if this isn't true it sends the
    #request to index.php
    RewriteCond $1 !^(index\.php|images|robots\.txt)
    Currently with this .htaccess any subfolder request at the end of the url goes to CI of course.
  • #2 / Sep 14, 2010 6:24pm
    12vunion
    You already have a spot in there for that:
    Just add the folders you’d like to skip from being passed into index.php
    RewriteCond $1 !^(index\.php|images|subfolder1|subfolder2|robots\.txt)
  • #3 / Sep 14, 2010 6:57pm
    Zelf
    In my subfolder I have a .htaccess file for password authentication.  This is what appears to be causing the problem.  If I remove the .htaccess file from my subfolder it loads fine.
    Any ideas how I can overcome this? subfolder needs to be password protected.
  • #4 / Sep 14, 2010 7:05pm
    WanWizard's avatar
    WanWizard
    You must have another issue, because
    should already be sufficient to stop the rewrite of a request for a valid file in that subfolder.
  • #5 / Sep 14, 2010 7:17pm
    Zelf
    Finally found the solution in the forums.
    RewriteCond $1 !^(401.shtml)
    as I saw in another post needs to be added to root .htaccess before the last rewrite line.
