Problem in generating pdf through plugin....
June 29, 2009 1:46am
  • #1 / Jun 29, 2009 1:46am
    zombica
    Hey guys i m using a pdf generation plugin available for CI.
    Available over here http://www.digitaljunkies.ca/dompdf/downloads.php#doc
    Problem is that :
    Here is my controller class pdf function
    function pdf($cid)
    $this->load->plugin('to_pdf');
    $this->load->helper('typography');
    $data['pageTitle'] = 'Case Detail';
    $caseInfo = $this->casemodel->get_single_case($cid);
    $data['singlecaseView'] = $this->casemodel->get_single_case($cid);
    $data['row'] = $this->casemodel->get_single_case($cid);
    $html = $this->load->view('pdf', $data, true);exit;
    pdf_create($html, 'case_'.$data['row']->caseId);
    and here is my view pdf file code
    <? include(“layouts/Adminheader.php”);?>
    <? foreach($singlecaseView as $caseView):?>
    <table cellpadding=“0” cellspacing=“0” border=“0” width=“800”>
      <tr>
      <td width=“60%”>Invoice <?=$caseView->caseId;?>
          <?= date(‘F d, Y’, mysql_to_unix($caseView->date_created));?>
      </td>
      <td>
    <?= $caseView->case_name;?>
          <?= $caseView->lfname;?><?= $caseView->llname;?>
          <?= $caseView->tfname;?><?= $caseView->tlname;?>
          <?= $caseView->detail;?>,
          <?= $caseView->case_status;?>
      </td>
      </tr>
    </table>
    <? endforeach;?>
    <? $name;
    exit;
    <? include(“layouts/Adminfooter.php”);?>
    problem is that in controller function pdf() it loads my view page and displays all the data on view page but it does not reads pdf_create($html, ‘case_’.$data[‘row’]->caseId); function and does not comes into it.
    Is some thing i am missing and where does this pdf file will be generated. Where can i see my pdf generated file.
    Thanx in advance.
    Regards…..
  • #2 / Jun 29, 2009 2:38am
    zombica
    Hey Guys does PDF generation plugin support for CI given by Derek Allard…
    Does not support tables,tr,td. Do i have to use only the paragraph, headings, li or some thing like this.
  • #3 / Jun 29, 2009 3:25am
    Thorpe Obazee
    The library is dompdf by http://code.google.com/p/dompdf/. It has support for tables.
  • #4 / Jun 29, 2009 3:35am
    zombica
    Thanx i got that….
    Regards…
    Zombica
  • #5 / Jun 29, 2009 10:34am
    johnwbaxter's avatar
    johnwbaxter
    Why don’t you take a look at the code for bambooinvoice.org which uses this pdf lib?
