Displaying comments on index/multi entry pages. Does adding pagination break this?
May 25, 2009 1:31pm
  • #1 / May 25, 2009 1:31pm
    justjess
    I am currently able to display comments on the index/category pages of my site by embedding a comments template and passing the weblog and entry id variables as is demonstrated in the wiki.
    My main template contains:
    {embed="includes/homepagecomments"  comment_total="{comment_total}" entry_id="{entry_id}" title="{title}" url_title="{url_title}"}
    My comments template contains:
    {exp:comment:entries weblog="{my_weblog}" limit="20" orderby="date" sort="desc" entry_id="{embed:entry_id}"}
    {url_as_author} said: {comment} <span class="posteddate">on {comment_date format='%m.%d.%y'}</span>
    {/exp:comment:entries}
    However, adding pagination to the mix on the primary template creates erratic results. Should this functionality be possible? Do I need to resort to a direct query in order for it to work?
    Thanks in advance,
    Jess
  • #2 / May 25, 2009 2:57pm
    e-man
    Yup, pagination messes with displaying comments.
    Have a look at this older thread to give you an idea for a workaround: http://ellislab.com/forums/viewthread/97723/
  • #3 / May 25, 2009 3:16pm
    justjess
    Hey, thanks so much for this quick response! I had seen that thread, so I guess I’ll have to take the query plunge.
    Thanks again,
    Jess
  • #4 / May 25, 2009 3:23pm
    e-man
    No prob, don’t hesitate to post your code here if/when you run into trouble.
  • #5 / May 26, 2009 10:49am
    justjess
    OK, so I’ve quickly run into trouble 😊
    I am able to get comments using this query:
    <pre><code>{exp:query sql="SELECT * FROM exp_comments where entry_id='{embed:entry_id}’”}
    {url_as_author} {url} {name} said: {comment} on {comment_date format='%m.%d.%y'}
    {/exp:query}<pre><code>
    First - {url_as_author} does not work. I added in {url} and {name} as tests, so I suppose I can just create the link a different way.
    Second - this query replicates the strange pagination behavior. I am guessing this is because I start out with a conditional that tests for {comment_total} from the parent template. (These are hide/show comment boxes in hidden divs. They only appear if a comment exists, thus the conditional).
    Would you recommend that I instead test for {total_comments}? I tried adding it in, but it doesn’t seem to work either?
  • #6 / May 26, 2009 10:53am
    e-man
    Care to post a link or show your complete template code, not just the embed?
  • #7 / May 26, 2009 11:46am
    justjess
    yes to both. link is here:
    http://jaypremack.net/index.php?/jpw/indexrev/
    main template
    thanks so much for the continued support - this is a beast!
